Visualize Tab doesn't exist
Message 1 of 10
Hello
I've downloaded Autocad 2016 educational version
But I can not render because Visualize tab doesnt exits and when i write 'render' in command line it renders but quality is horrible because I can not edit settings..
I uploaded pictures please help..
thank you
Replies (9)
Message 2 of 10
Alfred.NESWADBA
the "Visualize" tab only exists in the 3D-modelling workspace (OOTB).
Switch to that workspace and do your 3D-stuff.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 10
thanks a lot
Message 4 of 10
When I show the Menu bar, the Visualize tab still doesn't show.  What am I missing?
Message 5 of 10
Alfred.NESWADBA
In the old pull-down menus there does not exist a "Visualize" item.
You need to use the ribbons, and there the workspace "3D Modelling".
- alfred -
Alfred NESWADBA
Message 6 of 10
Alfred,
Nowhere am I seeing the word "Visualize," on menus or on tabs. I have,
along the top of my screen:
File
Edit
View
Insert
Format
Tools
Draw
Dimension
Modify
Window
Help
Express; and
Parametric
Next to "Home," I see:
Solid
Surface
Mesh
Render
Parametric
Insert
Annotate
Layout
View
Manage
Output
Plug-ins
Online
ExpressTools
FeaturedApps
BIM 360; and
Performance.
Where is the Visualize tab supposed to reside?
Nancy
Message 7 of 10
Alfred.NESWADBA
>> Solid
>> Surface
>> Mesh
>> Render
Well, "Render" is then what you are looking for.
The thread here is discussing AutoCAD 2016, the name of this item changed with AutoCAD 2015 (>= 2015 ... "Visualize", <= 2014 ... "Render").
- alfred -
Alfred NESWADBA
Message 8 of 10
msweeney
Community Visitor
Community Visitor
I have AutoCAD LT 2016 and also don't have the visualize tab or render.  Could it be that I paid Autodesk hundreds of dollars to upgrade from the previous version and they took away that feature on LT with 2016?
Message 9 of 10
Alfred.NESWADBA
AutoCAD LT is the small brother of AutoCAD, reduced to 2D and no API for customization. Rendering is a 3D-function, so not supported on AutoCAD LT.
To proof that: try to type in manually:
_RENDER<ENTER>
I guess you get "unknown command", am I correct?
You can also look to that comparision table between AutoCAD and AutoCAD LT >>>click<<<
I don't know which version and type you had before, but LT never had a _RENDER command.
- alfred -
Alfred NESWADBA
Message 10 of 10
Patchy
LT let you do that before upgrade? Not from what it shows here:
