FATAL ERROR: Unhandled e0434352h Exception at fab4a1c8h
jared
jared
Error Report # CER_123387143
When opening via DWG into AutoCAD 2015, receiving Crash at Launch. Anyone have a solution to this?
wispoxy
First try the following.
Uninstall and reinstall AutoCAD using the following instructions:
  1. Disable your antivirus program.
  2. Uninstall Microsoft .NET Framework (see How to remove and reinstall the Microsoft .NET Framework).
  3. Uninstall Microsoft Visual C++ Runtime Libraries (see How to remove and reinstall Microsoft Visual C++ Runtime Libraries).
  4. Uninstall AutoCAD (see Removing Installed Products).
  5. Restart the computer.
  6. Install AutoCAD and then reboot once more.
  7. Launch AutoCAD as Administrator, at least for the first time (see How to set a program to run as administrator).
  8. Enable your antivirus program.
Article ID: kA230000000eFnW
Then try this. The following may or may not apply to 2016 versions or newer. Some suggestions are said a second time, please excuse them. Thank you.
Do these in order, top to bottom.
    • Uninstall any antivirus or desktop locking programs.
      These programs can cause errors in AutoCAD, since they prevent the system environment from working.
    • If DisplayLink Core software is installed on your system, try uninstalling it.
