Hallow
There are green broken lines inside model in front of red arrows.How can I do like this
Solved by nestly2. Go to Solution.
Start with "Hidden" Visual style and turn on Occluded Edges, set color and linetype as desired. (may also want to reduce the width of Silhouette Edges)
Having said that, I really don't recommend doing it that way, especially for plotting. I'd use one of the tools intended to create 2D documentation from 3D models ie VIEWBASE, FLATSHOT, SOLPROF
Thank you very much for your help
