Visibility on block not working
jason.bowman
Message 1 of 15
jason.bowman
I have a block we use as a sprinkler head with some visibility states so we can change whether it is on a rise pipe/pendent etc. But on the most recent project I'm on, I've gone back in to the drawing and the block isn't working.
I can't really explain anything other than that as I have no idea why its happened but I have attached two screenshots and the block in question. I need to get this drawing issues ASAP, which I why I was going into the drawing, this is a huge dampener on the project as there's 400+ heads and not a single one is visible.
Fig 1 shows how they should look, Fig 2 shows how they currently look. I got Fig 1 from a revised drawing which I cannot issue.
Block attached.
Replies (14)
Message 2 of 15
Todd_Rogers
I opened up the block and the units are set to Meters. Is this what it's supposed to be? or Feet?
Todd Rogers
Civil Administration
Message 3 of 15
jason.bowman
The units are set as we use, the units have nothing to do with the issue anyway.
Message 4 of 15
jason.bowman
Message 5 of 15
Todd_Rogers
The block is set to Meters, and if you insert it, it changes to millimeters. What is your INSUNITS set to?
Todd Rogers
Message 6 of 15
Todd_Rogers
Todd Rogers
Message 7 of 15
oswaldodcb
Hello @jason.bowman
I think it is the WIPEOUT that is ahead of the figure, to fix that problem enters the block from the BLOCK EDITOR, select the VISIBILITY MODE button to turn on all the visual states, then go to the drawing and select a WIPEOUT, press click Right and SELECT SIMILAR, send all the WIPEOUT backwards with the command DRAW ORDER + BACK. Then press VISIBILITY MODE again and save the block and close.
I hope it works for you,
Oswaldo Caballero
Project Engineer / Autodesk Certified Instructor / Autodesk AutoCAD Certified User and Professional
Maracaibo, Venezuela
LinkedIn
Da un Me Gusta si la publicación ha sido de utilidad y si ha resuelto tu duda presiona ACEPTAR SOLUCIÓN
Message 8 of 15
jason.bowman
4 - Millimetres, its worked fine for years and we've always kept it like that, so I'm assuming the units aren't the problem? My guess is it's the visibility as some states work, some don't?
Message 9 of 15
jason.bowman
Message 10 of 15
jason.bowman
I've tried this before posting, if I move the wipeout then it alters the states, so a pendent head (where the wipeout DOESN'T covers my red range pipe) appears as a pendent head (which DOES cover the red range)
I like the thinking though.
Message 11 of 15
jason.bowman
Message 12 of 15
oswaldodcb
@jason.bowman It seems that the problem is the WIPEOUTFRAME variable, you must have it in 0, put it in 1 and you will see how the blocks are displayed well,
I hope it helps you,
Oswaldo Caballero
LinkedIn
Message 13 of 15
jason.bowman
THAT WORKED!!!
Thank you very much, don't know why I didn't think to try that, must be the pressure
Kudos to you! 🙂
Message 14 of 15
jason.bowman
THAT WORKED!!!
Kudos to you! 🙂
Message 15 of 15
oswaldodcb
You're welcome and I'm glad it worked!!
Success! @jason.bowman
Oswaldo Caballero
LinkedIn
