I working on a pipeline project that has many long rectangular viewports along its length, five in this instance. I have created a xref file in which I have stored a named modelspace view for each viewport. From a sheet set I then generated five drawings each with the named modelspace as a sheet view. The modelspace views overlap on each side with the adjacent ones.
Sheet 1 appears different from the remaining sheets, even the parts that are overlapping. In particular lines showing up in sheet 2 are missing from sheet 1 (eg over head power that runs through all sheets) To start with I tested the process with 1 named modelspace and one sheet, and when it worked I created the rest. I actually have a large number of sheets to go and wanted to check I had my process correct before going to far.
Initially I had an issue where Sheet 1 viewport wouldnt print, so I deleted it and brought the model view back in. This fixed it, however the layout was different from the adjacent sheets. I then deleted Sheet 1 completely from the set and harddrive, and made a new copy from Sheet 2 and updated with the correct model space view. The problem still persisted so I deleted the original Sheet 1 model space view and regenerated it, but the issue persist.
I have checked the properties of the viewports, drawings and named modelspace views and the settings appear the same.
A sample of sheet 1 and 2 overlap area is below. I have highlighted the common car/solar panels for reference, and in sheet 2 the lines that should be extending over to Sheet 1. The yellow vertical lines are non-printing rectangles outlining the extent of eachsheet in model space.
Sheet 1
Sheet 2
Hi @Anonymous,
Thank you for your post. It sounds like there might be a conflict between sheets or possibly file corruption. Is this occurring with any other sheet sets? Are you starting with a custom drawing template or reusing a drawing?
Maybe try repairing the drawing files first as explained in the following AutoCAD Knowledge Network (AKN) articles:
How to repair corrupt AutoCAD files
Optimizing the AutoCAD drawing file: Purge, Audit & Recover
If you continue to have trouble after this, can you provide the drawing using the the ETRANSMIT command which will let you bundle all reference files together.
If a post was helpful, Likes are always welcome.
Please click the Accept Solution button for any posts that resolve the issue or answer your question.
All the best,
Thanks Cheryl,
I have tried a couple of the items but it hasnt worked. I will keep working through it.
However I created a new named model view BUT with a different title (eg 1A instead of 1) and it has fixed the issue.
Regards
Brian
Hi @Anonymous,
When replacing a view entirely resolves the issue, it's often an indication of a conflict or corruption. I am glad to hear that worked for you.
All the best,
