AutoCAD Forum
Viewport won't print certain layout
1 REPLY 1
552 Views, 1 Reply
Hello, needing help with a viewport problem...
Most of my viewports are printing bar 4. The viewports are all in the same layer, all set as printable, but will not print on 2 of the 3 printers. The printer that is able to print them is a laser A4 printer. The two struggling, and only printing the key and bottom info part, are an A3 printer and a plotter.
Does anybody know anything that might be able to help? Printing preview shows the viewport and lines inside as printing, but as soon as it makes it's way out the printer they have vanished...
1 REPLY 1
pendean
As a test, only a test, can your A3 printer and Plotter print all the viewports if they were on an A4 size sheet? What make/model and drivers are these A3 printer and plotter? Which Windows version are you using? And What's your AutoCAD version?
Forma Design Contest
