Viewport Scale
Viewport Scale
Viewport Scale
In paperspace, I have my viewport set to a specific scale.  When I select my viewport, I don't see the scale listed anywhere in the properties.
Where is the scale of viewports listed?
BeKirra
On layout,
1) Select the viewport,
2) Type properties in command line,
3) In "Misc" section, there are "Standard Scale" and "Custom Scale".
BTW you may consider to set system variable "pickfirst" to "1".
HTH
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
is that^ what you were looking for? or do you need to add to the scale list? to do that type scalelistedit then do a reset
