Viewport scale
Viewport scale
mbr94TK7PQ
Message 1 of 14
Viewport scale
mbr94TK7PQ
Using AutoCad Lt. 2021 on Windows 10.
When I zoom in on model view port to select a dimension point, the scale is lost and I have to rescale the viewport.   The paper space view port is definitely 'Locked', yet the scale changes when I zoom in.  Is there a system variable that may control this?   Any suggestions for solution?
Replies (13)
Message 2 of 14
imadHabash
NO ... it can not be happened !!! if your paper space VP is really locked , the VP scale wouldn't be changed if you pick inside it . make sure that your VP is locked by :
  • select your VP then press Ctrl+1 , check from Properties dialog that you select a VP NOT a rectangle and from Misc tab check if Display locked = Yes
  • from Status bar check the Lock icon = Blue .
Imad Habash
Message 3 of 14
ChicagoLooper
Right-click directly on your viewport and from the shortcut menu, you’ll have the option to lock it.
Chicagolooper
Message 4 of 14
mbr94TK7PQ
I’m quite familiar with the command you mentioned, but it does not work. The VP shows to be locked, but when I go into model view, and zoom in to lock in on a dimension point, the scale is lost.
Message 5 of 14
imadHabash
can we have a CAD dwg sample for testing please ?
Imad Habash
Message 6 of 14
Grover_Puma
if I could share DWG file this would help to solve the problem. Thank you
ACEPTA LA SOLUCION que responde a tu pregunta, esto ayudará a otros a encontrar respuestas de una manera mas sencilla.
Si te gusta esta publicación, dale ME GUSTA.
Saludos!
Message 7 of 14
ChicagoLooper
FYI, if you are locking the viewport in the Layer Properties Manager then the viewport is NOT locked. You will need to use your mouse. Click directly on the border of your viewport then select DISPLAY LOCKED=>YES.
Chicagolooper
Message 8 of 14
ChicagoLooper
@mbr94TK7PQ wrote:
.....but when I go into model view, and zoom in to lock in on a dimension point, the scale is lost......
What does the above statement mean? Please explain 'go into model view' using a detailed description. Please explain 'to lock in on a dimension point' using a detailed description. Apparently there's a communication breakdown and can help by clearing it up. Thank you for understanding.
Chicagolooper
Message 9 of 14
mbr94TK7PQ
I will send a DWG file on Monday
Sent from my Verizon ASUS Tablet
Message 10 of 14
mbr94TK7PQ
When I am in a plot file, and in the paper view, when I click to the model view and zoom into the viewport to lock on a dimension point, then zoom out, the scale changes.
Hopefully, this explains, but if not, let me know.
Marshall
865-776-2201
Message 11 of 14
vinodkl
when you are in paperspace and have the viewport locked and want to edit the model space element then select the viewport and type in the command "VPMAX" and to return back the paper space type in "VPMIN". Does the viewport scale still change now?
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Message 12 of 14
mbr94TK7PQ
I tried your suggestion. When I click on viewport, type in VPMAX, and go into model drawing and add dimensions then type in VPMIN. When it returns to paper space, the viewport is blank with no image and is black.
Message 13 of 14
vinodkl
We can help you out only if we have anything (like screenshot or screen record using Autodesk screencast) to see what is going on in your end. Else it would be difficult for us to provide a definite solution to your problem.
Message 14 of 14
ChicagoLooper
@mbr94TK7PQ wrote:
.........when I click to the model view and zoom into the viewport to lock on a dimension point.........
What is a dimension point? How do you create a dimension point? Please upload a screenshot of a dimension point.
Chicagolooper
