Viewport Scale List
Viewport Scale List
Message 1 of 9
Viewport Scale List
I am in AutoCAD 2016.
I am wanting to change the viewport scale of a viewport in paperspace.  I can do that, but I do not see the scales I am used to.  Normally I see a long list which includes scales like
1/8" = 1'-0"
1/4" = 1'-0"
1/16" = 1'-0"
etc.
Instead of that, I see a different list which includes only scales like
1:2
1:5
1:10
1:100
etc.
I am working in a drawing here at our company.  I do not know who created this drawing but I am guessing they created a new drawing from a default template.
Every drawing I have worked with here has had the inch/foot type scales listed.
I can choose "custom" or type SCALELISTEDIT and add scales individually but I would like to import or add the entire list of scales with inches/feet that I usually see.  Is this possible?
Also, for reference, I have changed the units in the bottom bar menu to "Architectural".  And I have used the UNITS command and changed the units to inches (which is what I usually have it at).  Not sure if I need to change any other settings.
Thank you for any help.
Replies (8)
Message 2 of 9
imadHabash
HI,
from OPTIONS command you can get that. use Imperial option as seen from below attached image.
Regards,,
Imad Habash
Message 3 of 9
Somehow the "Default Scale List" option isn't even there.  What is wrong with my program.  (shown in screenshot)
Message 4 of 9
imadHabash
the above post for me was for using default mode.so all what you need is to press Reset button from scalelistedit dialog.
Good Luck..
Imad Habash
Message 5 of 9
After going to SCALELISTEDIT and clicking "Reset" and choosing Imperial scales only and clicking OK and doing the SCALELISTEDIT command again, this (the attached screenshot) is what shows up: the same scale list as before (1:100, etc.), none of the inch/feet ones.  And "Default Scale List" is still not available in Options->User Preferences after this either.
Message 6 of 9
imadHabash
i use AutoCAD 2017,and i don't remember if it's exist in another place or what.
Imad Habash
Message 7 of 9
imadHabash
HI,
it's fine with me.please try to do it carefully again and see.if NOT try to install the latest service pack HERE .
Imad Habash
Message 8 of 9
Check which version you are using. The screenshot you posted is showing that you are using AutoCAD ARCH 2016. This may require a reinstall to get the imperial units loaded.
Message 9 of 9
you can always try the sledgehammer approach:
(defun c:msca ()
	(command "-scalelistedit" "d" "*"
			"add" "1/8\" =  1'-0\"" "0.125:12"
			"add" "3/16\" =  1'-0\"" "0.1875:12"
			"add" "1/4\" =  1'-0\"" "0.25:12"
			"add" "3/8\" =  1'-0\"" "0.375:12"
			"add" "1/2\" =  1'-0\"" "0.5:12"
			"add" "3/4\" =  1'-0\"" "0.75:12"
			"add" "1\" =  1'-0\"" "1:12"
			"add" "1 1/2\" =  1'-0\"" "1.5:12"
			"add" "3\" =  1'-0\"" "3:12"
			"add" "1\" =  10'-0\"" "1:120"
			"add" "1\" =  20'-0\"" "1:240"
			"add" "1\" =  30'-0\"" "1:360"
			"add" "1\" =  40'-0\"" "1:480"
			"add" "1\" =  50'-0\"" "1:600"
			"add" "1\" =  60'-0\"" "1:720"
			"add" "1\" = 100'-0\"" "1:1200"
			"add" "1\" = 200'-0\"" "1:2400"
			"add" "1\" = 300'-0\"" "1:3600"
			"add" "1\" = 400'-0\"" "1:4800"
			"add" "1\" = 500'-0\"" "1:6000"
			"exit")
