Viewport scale list 1:500 doesn’t work but z 1/500xp does
Khernmega85
Observer Observer
Khernmega85
Observer
Observer
I’m in 2025 Arch and drawing in meters, setting up a page to print. Page setup units are 1:1 (1mm =.001 units).
When selecting 1:500 in the scale list the viewport zooms in super close (incorrectly), but using the z 1/500xp command calibrates the viewport correctly https://xender.vip/ .
Am I missing something for why the viewport scale list isn’t scaling properly?
imadHabash
>> ...but using the z 1/500xp command calibrates the viewport correctly.
Can you explain it please?
Imad Habash
paullimapa
Enter Scalelistedit command then select 1:500 to edit and see if the entry shows a different value compared to 1/500
Paul Li
IT Specialist
@The Office
pendean
Community Legend
Community Legend
@Khernmega85 wrote:
...Am I missing something for why the viewport scale list isn’t scaling properly?
Are you 100% sure your DWG file is mm based? Plot scales are based on mm, if your DWG is set to anything else (meters for example, or worse, inches) you have some calculating to do.
