Viewport Scale feet/inches. Old problem new confusion.
I am a humble seeker trying to understand the mysteries of AutoCAD.  Perhaps the answer is as obvious as water to a fish.
Drawing is attached.
Units set to Decimal Feet
Circle radius of 1 (i.e. 1 unit, or in this case 1 foot)
First viewport Scale 1:1
And yet - the circle has a radius of 1 inch, while I expected it to have a radius of 1 foot.
Second viewport Scale of 1"= 1'-0" (8.33%)
And yet - the circle appears to have a radius of 1/12 of an inch, while I expected a circle with radius of 1 inch.
To AutoCAD a unit is a unit is a unit.
And yet - the proverbial rubber meets the proverbial road in the page setup, where ANSI D really does mean 22" x 34" with reference (roughly) to the width of the (actual) human thumb.
Can someone help me to see?
murray-clack
In my company, we have two Dimstyles.  One for Architectural inch units, and one for Architectural decimal units
See attached file
Thanks Murray -
Yes, I am curious why "Unit Format" in the dimension style dialog seems to override the drawing units dialog.
I would expect that a one-unit-long line in a drawing with units set to feet would dimension as
1'-0" with unit format set to Architectural
1.00 with unit format set to Decimal
Instead we get 1" and 1.00 as you show.
pendean
Community Legend
Community Legend
Drawing Units do not controls everything: you the user determines what dimstyles do follow or ignore. Does that help?
Hmm - maybe.
It is at best unintuitive that the dimension style can turn what I thought was a 12" line into a 1" line, effectively scaling the drawing by 1/12.
I suppose this functionality accommodates a difference of worldviews at the discipline-level (architectural vs engineering) that pre-existed AutoCAD.
I work at a wastewater utility.  One drawing set will have both civil-scale drawings and instrument-scale drawings.  Remembering what's what, and sharing content between them can be confounding.  Such is life.
Bob_Zurunkle
OP without looking at your drawing it sounds like the difference between units being set to 'architectural - feet and inches' and being set to 'engineering'. In the first setting, 1 unit is an inch. In the second, one unit is one unit, often used to represent one foot.
If by some odd chance my nattering was useful -- that's great, glad to help. But if it actually solved your issue, then please mark my solution as accepted 🙂
