Viewport Scale Dropdown location
nfranklin9Q4AQ
nfranklin9Q4AQ
Hey All,
I'm running autocad '24
The scale setting dropdown button is aligning off my sheet and screwing up my plot.
Does anyone have a fix for this?
paullimapa
This could be related on how the vport boundary is with all those in and out corner points. Does this only happen with this vport on this layout? Have you tried creating a more simple vport boundary to see if that resolves the issue?  What if you use the Properties windows Scale drop down list to select a different display scale?
Paul Li
IT Specialist
@The Office
imadHabash
It would be more useful if you share your file with us here so that we can see together the best way to handle the matter?
Imad Habash
