Viewport outline color
jwright1962
jwright1962
Hello Forum:
I have 2 viewports in paperspace.   One is rectangular and the other is a polygon (5 sides).   I can change the viewport outline of the rectangular one to red, green, yellow...  etc...   but the polygon shaped viewport remains white...  the color in the properties dialog box says red, green, yellow... etc...  but the outline itself remains white?   is this by design?  if not what have I done wrong...  can I change the color of a polygonal viewport outline ?
pendean
Community Legend
Community Legend
What version of AutoCAD are you using as listed in ABOUT command?
Can you share your DWG file with this problem in place?
Did you use VpClip? If you want the 5 sided polygonal viewport to be same color as your viewport layer color. You need to make the viewport layer current, then redo the VPclip. The viewport should now by the color of the current layer.
ChicagoLooper
You may need to recreate the polygonal viewport. Delete the  polygonal viewport, then redarw it.
  1. Start by making the 0 layer current, then drawing the desired perimeter of your polygonal on the 0 layer.
  2. Make sure this polygon's color is set to ByLayer such that 'ByLayer' is displayed in the Properties Palette under Color when this polygon is selected.
  3. Convert this polygon into a viewport using ByObject option (From layout contextual tab=>Layout Viewports Panel)
  4. Move this newly created viewport to a new layer dedicated to this single viewport where the VP can inherit the new layer's color.
Chicagolooper
Thomas_Stuehle
Hello @jwright1962
Did the posts above help you and answered your question?
If yes, feel free to click on the button "Mark as Solution". Thus also other users can benefit from the information. In case you still need help please feel free to provide an update here so we as Community know how we can help you best moving forward.
Best regards,
Thomas
Your question got successfully answered? Then just click on the 'Mark as solution' button.
Thomas Stühle
Technical Support Specialist
GrantsPirate
The polygonal viewport will be made up of two objects, use the crossing selection method and set them both to the same layer or just set the color if you want.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
