AutoCAD Forum
viewing printing right to left language like arabic
2 REPLIES 2
1491 Views, 2 Replies
Dear All
i'm usin autocad since version 14 till now so we used to use fonts like xarab sosa to write arabic and things goes ok
after autocad annonced that autocad support true type fonts we try to use windows fonts to write arabic in autocad rarly it's ok
the problem when printing even print as graphic option is checked the text come revirsed horizontaly thats comes with all autocad version event 2016 and when we write arabic and pan zoom the screen the text also corupted horizintaly
i'm askin is autodesk still not realy support languages from right to left cause using the xarab fonts is not the big solution that when you import text from revit world any other apps you can't use xarab
any news that autodesk will support RTL langauges like revit or other application that support unicode
or any recent solultion third party app that bring suppot to autocad
i attached a gif descrip how arabic ttf present in autocad 2016
Tags (1)
2 REPLIES 2
imadHabash
HI,
kindly see attached image to write with arabic from right to left and without zoom problems despite of that arabic fonts still need a lot of efforts to work fine with autocad...
Good Luck..
Imad Habash
in reply to: imadHabash
even with mtext the problem is still
Technology Administrators
AutoCAD Beta
