viewbase macro problem
geraldbossink
geraldbossink
Working with ACAD2023 on Win10Pro, I'm trying to write a macro for a viewbase-command:
^C^C-viewbase;m;h;v;o;c;s;0.1;e;r;all;add;\\
The command needs to run the viewbase command, change to Mspace, deselect all and add the selected opbjects. Everything runs fine, until the add-part. For some reason, after ...r;all; some objects stay selected and the 'add' gives a problem:
Command: -viewbase
VIEWBASE
Specify model source [Model space/File] <Model space>: m
Specify location of base view or [Type/sElect/Orientation/Hidden lines/Scale/Visibility] <Type>: h
Select style [Visible lines/vIsible and hidden lines/Shaded with visible lines/sHaded with visible and hidden lines] <Visible and hidden lines>: v
Specify location of base view or [Type/sElect/Orientation/Hidden lines/Scale/Visibility] <Type>: o
Select orientation [Current/Top/Bottom/Left/Right/Front/BAck/SW iso/SE iso/NE iso/NW iso] <Front>: c
Specify location of base view or [Type/sElect/Orientation/Hidden lines/Scale/Visibility] <Type>: s
Enter scale <0.001>: 0.1
Specify location of base view or [Type/sElect/Orientation/Hidden lines/Scale/Visibility] <Type>: e
Restoring cached viewports.
Command:
Select objects to add or [Remove/Entire model/LAYout] <return to layout>: r
Select objects to remove or [LAYout]: all
726 found
Select objects to remove or [LAYout]: add
52 found, 52 total
What am I missing here?
cadffm
>>"What am I missing here?"
I am missing here the original text log, it looks like you posted not the original one.
How did you copy this log, from where and how did you copied?
How should we know that without your drawing (is it drawing dependend?)
and without to know your both clickpoint for your object selection?
And if the problem is really random: Nobody can fix a random problem,
you need to find more details about the issue.
After "remove all", when AutoDESK asking for (add) objects, in this moment: Can you see highlighted/selection objects?
(this is what I imagine frome your post)
Sebastian
geraldbossink
@cadffm: the log is copied from the text window after running the command, it's the original one. And since the porblem is drawing-independent I didn't post the drawing. In my opinion it's something in the macro I'm missing, not something in the drawing.
Running the series of commands on the command line manually works fine, when putting it in a macro it isn't
cadffm
ahh okay, my fail:
The textlog was different because I compared it with a manually typed in sequence,
in this case the feedback of object selection looks like:
3 found, 2 removed, 0 total
instead of the macro feedback
2 found
Back to the topic:
>>". In my opinion it's something in the macro I'm missing, not something in the drawing."
So is it a problem in every file, in every macro-run you trying?
Or random...?
Sebastian
cadffm
NOW I can see what you see!
crazy
If I have time for it, I will send my feedback.
Sebastian
geraldbossink
It looks like a problem I had with a join command. In that case the macro ran an older join-command than when typed in the command line or using the join-button in the ribbon (old join command didn't allow multiple object selection, new join-command did). Solution in that case was to add ^R in front of the join-command in the macro, in order to run the new join-command. I tried this for the viewbase-command, but didn't work out.
cadffm
Join command: Right, that was another thing you stumbled over.
1. The Viewbase command (not -viewbase) , started by hand or by macro is the same "version",
but the switch "from remove all to the ADD method" works differently 😕
2. Looks like a kind of bug, send feedback to AutoDESK or start a supportcase or any other way to inform about this issue.
  Not related to 2023! (did you searched about this problem in older posts? I didn't)
3.  If you can't find a solution, go the workaround, for example by Lisp-Command
(command "_.VIEWBASE" "_m" "_h" "_v" "_o" "_c" "_s" "0.1" "_e" "_r" "_all" "_add" (ssget "_:S"))
or
(command "_.VIEWBASE" "_m" "_h" "_v" "_o" "_c" "_s" "0.1" "_e" "_r" "_all" "_add" (ssget "_:S") "" PAUSE)
or
(command "_.VIEWBASE" "_m" "_h" "_v" "_o" "_c" "_s" "0.1" "_e" "_r" "_all" "_add" (ssget "_:S") "" PAUSE "")
"" means <enter> or ;
"whatever" means whatever<enter> or whatever;
PAUSE means ONE userinput or \
Sebastian
