VIEWBASE - inventor server failed to load
Windows 7, 64-bit, service pack 2 installed. Have the same problem, looking for a solution.
It works intermittently, not sure why, was working for a month, now is not. No updates done since.
Any suggestions?
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
Please give me a bit more information. Are you seeing this error on all drawings or just specific ones?
Here is an article that describes possible causes and solutions including Registry errors, drawings that came from other products, invalid paths.
It might be time to do a clean uninstall of your AutoCAD and reinstall to remedy this problem.
John Vellek
Thank you for your response John.
It happened on the last 3D model I was trying to convert...
I will try to uninstall.
Gabriel
john.vellek
Hi Gabriel,
I am checking back to see if my post helped you with your problem. Did the reinstall help the issue? Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
