View Cube
View Cube
View Cube
In My layout  view cube 45 digrees rotated but drawing view is ok,
in model view cube is ok
 how to solve the problem ?
 plz fiend the attached jpeg
Valentin_CAD
Have you tried to "Restore Defaults" in the ViewCubeSettings?
Or have your view as Top - Type View and set current TOP?
Most likely is the setting in GEOGRAPHICLOCATION
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
imadHabash
I suggest to change your UCSFOLLOW system variable to 1. click inside VP then change it.
Command: UCSFOLLOW
Enter new value for UCSFOLLOW <0>: 1
Good Luck..
Imad Habash
rkmcswain
In your layout, the model in the viewport has had the UCS rotated, but the view has not been rotated to match the UCS.
Go into the viewport, type in UCS, set it to World.
