Very large XREF causing problems
Message 1 of 17
Hi!
A large xref in my drawing is making autocad very slow and hard to work with. The xref is a part of a map that I'm drawing lines on. The only reason the xref is there is so it can be plotted in the background of my drawing. I won't ever need to use the geometry in any way, it's only there as a visual representation. In other words, there's no reason for it to be so large.
Is there a clever way to greatly reduce the size?
For example, export the xref as a .png and importing it into my drawing? I know you can export and import png's, but it's difficult to get the scale and placement right. I'm hoping there's a better solution.
Replies (16)
Message 2 of 17
john.vellek
HI @Anonymous,
Please explain what is in the current Xref? does it have a lot of hatches for instance that can be removed?  If you like, I can give you a way to send me the file (how big is the file?) and I can make better suggestions.
You might try printing it to a PDF which you can then attach to your file and even snap to PDF geometry using PDFOSNAP.
John Vellek
Message 3 of 17
RobDraw
Make a copy of the .dwg and strip out all the unnecessary stuff. Also, purge, audit, etc. to clean up the file.
Rob
Message 4 of 17
massimo.corradi
Further more, apart purging and audit, here a couple of more suggestions.
Freeze layers that are not necessary to work.
If the xref is clipped remove clipping, that makes large files slow, especially if there are dense hatches.
If you have a single hatch for many separated areas, separate those hatches. The more contours the slower.
Check if objects properties are bylayer, having thousands of objects were properties are set makes a large drawing slow too.
To scale an image were a calculation is not possible to be applied check the command option 'relative' in the scale command. If you also need to rotate, then there is a scale option in the align command.
Message 5 of 17
ennujozlagam
Hello, you can try to DXFOUT to R12 and DXFIN again your xref drawings to reduce the file size, purge. Audit, overkill and see if helps. thanks
Message 6 of 17
john.vellek
Hi @Anonymous,
I am checking back to see if my post or others helped you with your problem. Please mark a post or posts as accepted solutions if they resolved the issue or give me a bit more detail on this issue so we can continue to work towards getting this solved.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
Message 7 of 17
Hi guys. Thanks for your replies.
I wasn't specific enough in my first post, my mistake. What I wanted to ask was this: Is there a way to drastically reduce the file size (from 30+ MB to say 2 MB or less)? Loosing object interactability (if that's a word) is totally fine, as long as it looks the same on screen and on print.
My original approach was to save as .png and try to place and scale the image to fit my drawing. This works ok (image file is less than 1 MB), but I'm hoping there's an easier solution.
The file is a part of a map (with height curves, roads etc). It consists of about one million objects, mostly polylines + a few thousand blocks and is about 32 MB in size. (For the record, I have no idea why it's made like this, I'm new at this company.)
I don't work with the file loaded. I unload it, and only use reload when I'm about to print. But this alone is enough to freeze my pc and make the process of printing a pain.
Overkill reduced the file by about 15 % (32 MB to 27 MB), while purge and audit did not reduce it. DXFOUT -> R12 made a 272 MB file :S
I can of cause freeze / delete everything i don't need, but I was hoping for an easier solution. (I need to see most of the geometry anyway) There are no hatches in the drawing.
Thanks for your help!
Message 8 of 17
hi,
use exporttautocad command may be it work try it or wblock
Message 9 of 17
john.vellek
Hi @Anonymous,
Can you share the file? I can provide an upload location if you wish.  I suspect that printing it to PDF and then using the PDF as an Underlay might be a way to eliminate the size problem.
Please let me know if you would like me to take a look at the DXF for you.
John Vellek
Message 10 of 17
Hi @john.vellek
Would be great if you could take a look at it!
Send me instructions, and I'll upload the file. It's about 32 MB.
Message 11 of 17
john.vellek
HI @Anonymous,
I took a look at your file and here is what I found:
Audit - 17 errors (12 erased objects)
Purge - 226 zero-length geometric objecgts
-Purge>Regapps - 23 Regapps
I erased some of the data around the edges of your map and then ran an exporttoautocad. After that process I was able to remove 4 more errors using Audit.
I then moved the entire contents close to 0,0.
The file was reduced in size a few MB.
Lastly, I plotted the contents to a DWF which results in a file that is about 3MB. You can attach the DWF to your other files and it should have a much smaller footprint.
I have uploaded my versions of your file to the same location where you shared your file.
John Vellek
Message 12 of 17
nathanhayes98
We had this issue before when using very large x-ref and there was a couple of ways we got around it
- Is your x-ref attached or overlayed? We found when the x-refs were attached they were causing a slow down in the drawing.
- Can your x-ref be clipped? Our x-ref was of a large highway so we cropped the xref down so it only showed the area we wanted, this also improved speed of drawings.
Message 13 of 17
Thanks @john.vellek! The .dwf works perfectly. Your method is exactly what I was looking for.
Thanks everyone for your help and ideas!
Message 14 of 17
Good Afternoon John,
I've a large Xref file size 27 MB, could you help reduce the size?
Message 15 of 17
nathanhayes98
Hi, try the steps below
Trying switching your xref to an overlay rather than attachment if you havent already.
Run the audit command to find and fix any errors in your model.
Run the purge command to get rid of any unused things.
Run purge>regreapps.
Message 16 of 17
Thanks for the response. The file is about 70 Mb, could you please help to reduce the size if I send the file?
Message 17 of 17
RobDraw
There are tons of threads about how to clean up/lighten drawings in this forum and many other places on the internet. Learning about this will teach things that can be used for other tasks.
Rob
