Trouble with save file
felipe_diazz
felipe_diazz
My trouble is when I try save the file in version 2017 of AutoCAD or AutoCAD Civil, this dialog appears and I can´t modified the file
Alfred.NESWADBA
AutoCAD or Civil 3D, that's now important to know.
In case you want to have the drawing in plain AutoCAD (Vanilla) and you don't have Civil 3D objects in that (or you need the Civil 3D objects to be converted to AutoCAD objects) then you might try to run command -EXPORTTOAUTOCAD
HTH, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
paullimapa
