Hi everyone. I'm hoping to find an answer from the collective knowledge here.
I work with a retail developer who builds site plans in Autocad (2015, I believe) for shopping centers. Within building spaces, they place tenant logos. Typically, they are converting vector Adobe Illustrator logo files to DWG, then exporting them to Autocad.
Everything is fine for their workflow. However, when they attempt to export the site plans out to PDFs, the logos end up with tons of complex shapes/rules within the logos. This creates thousands of points that are not needed. The files become absolutely massive, and using them in a PDF viewer is difficult. I have attached an image that shows what I see in Illustrator.
They use a plugin called Mcolor to map color outputs for things like tenant space colors or different rule widths for landscape features. I'm not sure that the plugin is causing the issue.
I have isolated the layers in Acrobat, and can turn off the logos. Once I import the non-logo file into Illustrator, the problems are gone, so I know it's in the logo workflow.
So, my question is, are there any workflows/processes/plugins that would keep the logos simple within Autocad and when they export out to PDF? I've seen other groups use bitmaps, but I'm hoping to keep higher quality when they're output at large sizes.
I really appreciate any insight anyone can offer!
