Message 1 of 9
Hi guys,
I'm writing here comming from a dillema.
I drew out a floorplan in autoCAD and different lines had different lineweights, but when I printed them out, the lines that were apart from each other for 4cm in real life and on the paper in 1:200 scale, it came out as one line and not two seperate when printed. Even when you view the pdf file after plotting it on acrobat the lines are appart when zoomed in but that isn't seen on the printed version.
I plotted it to pdf with ''as displayed'' and ''maximum quality'' settings and changed the dpi to 720dpi.
Could this be a printer issue or a software issue, + do you guys have any recommendations when it comes to this.
With kindes regards,
AF
