High quality PDF plotting
fetahu.ahmed
Message 1 of 9
fetahu.ahmed
Hi guys,
I'm writing here comming from a dillema.
I drew out a floorplan in autoCAD and different lines had different lineweights, but when I printed them out, the lines that were apart from each other for 4cm in real life and on the paper in 1:200 scale, it came out as one line and not two seperate when printed. Even when you view the pdf file after plotting it on acrobat the lines are appart when zoomed in but that isn't seen on the printed version.
I plotted it to pdf with ''as displayed'' and ''maximum quality'' settings and changed the dpi to 720dpi.
Could this be a printer issue or a software issue, + do you guys have any recommendations when it comes to this.
With kindes regards,
AF
Accepted solutions (3)
Replies (8)
Message 2 of 9
pendean
Community Legend
Community Legend
Are you using any lWIGHT or PLOT STYLE TABLE settings to control the quality of the lines?
Are you plotting to a scale in PDF that is large enough to show 4cm apart lines as two and not one?
Can you show us your PDF and at least a portion of your DWG file too?
Message 3 of 9
Alfred.NESWADBA
which lineweight did you use for that 2 parallel lines. This is important because 4cm reality distance plotted in a scale of 1:200 means the plotted distance is 0.2mm, so every lineweight >= 0.2mm means you can't see a gap between that two lines.
Change it to 2400 dpi or more, otherwise a lineweight of 0.1mm or 0.2mm can't be represented exactly enough.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 4 of 9
fetahu.ahmed
No I am not  😕  the scale might be the problem, on 1:200, 4cm is almost invisible..
thank you...do you have any recommendations how to improve the quality of the print ?
thank you very much,
with kindest regards,
AF
Message 5 of 9
Alfred.NESWADBA
As I wrote, change the resolution to something like 2400dpi or higher
- alfred -
Alfred NESWADBA
Message 6 of 9
john.vellek
Hi @fetahu.ahmed,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
I see that you have received some good suggestions here. If you want to attach your file and the plot style you are using I ma happy to try this on my side and therefore hope to make more suggestions.
John Vellek
Message 7 of 9
jayhar
https://youtu.be/_kUjk0fcvHI
Watch this video, enter comment PUB. Select precision on below, select MANAGE PRECISION PRESETS. Here select custom presets
You can see three option set all hi resolution in dip.
Thank you
Jayhar.M.J
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
Message 8 of 9
john.vellek
Hi @fetahu.ahmed,
Did you resolve your issue? Or, do you need me to take a look?  You are welcome to attach some files that I requested previously.
When I select my AutoCAD PDF (Highest Quality) driver, these are the defaults. Perhaps this is a good starting point for you.
John Vellek
Message 9 of 9
fetahu.ahmed
Thank you very much all for helping out, I solved the problem with your suggestions!
