hi,
I'm working on an existing building, mainly its roof...i know the roof drains are all 257mm lower then the perimeter, so i want to create a time saving dim style wich would give me:
the lengh of the line ( <> )
a % from a fixe "Z" (formula: 257/<>*100) wich is the actual slop on the roof expressed in %
and the formula <>*2% wich is the slop needed on the roof, expressed in %
I can create a dim style with 1. and 3. using alternate units... but how can i make it so it gives me 2. ?
I used insert field and formula in the edit of that linear dim, but it gives me the answer "#####"...
thanks in advance for the time you'll take to help me...
Martin
p.s.i dont want to spam... but i also made this post in the customization section... without any help...
@Marlec, john.vellek has edited your subject line for clarity:Variables in simstyles
hi,
Martin
Solved by Marlec. Go to Solution.
Hi Marlec,
Can you attach a sample drawing showing what you have done so far?
My first thought is to just add a field (not actually part of the dimstyle) that does this for you. You could group it with the dimension if that would help. I look forward to seeing what you have tried so far.
Hi Marlec,
This thread has been answered in the AutoLisp Customization newsgroup.
Hi,because there were'nt a lot of activities and needed to act rapidly, the original post is here:
http://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/variables-in-dim-style/td-p/6602910
I know that there can a lot of ways to do things... but if you have another idea i'm curious to see an alternative...
thanks in advance for the time you're allowing me..
regards....
Martin
regards....
Martin
