Using "View" Within Another Command
mgorecki
mgorecki
Maybe it was all in my imagination, but I thought there was a way to save a named view, then when I was zoomed up on a tight space, I could immediately jump to the saved named view.
For example, I saved a named view, then I zoom up on a spot.  I use Copy and grab a few items and pick a start point.  I thought one could use the inline View or Restore command to jump to the named view and complete the copy command.
Sure I could zoom out with the mouse wheel, but then I'd have to zoom up in the area I want and even then (because it's so cluttered with stuff) I would have to pan around to find the right spot.
I know I could also use zoom previous, but it would require 2 previous zooms.
Did this ever work inline, or am I just not remembering correctly?
Valentin_CAD
@mgorecki ,
Like:
You can use prefix characters with most AutoCAD internal commands. Such prefixes are e.g.:
"'" (apostrophe) transparency prefix (invokes a command during execution of another command - e.g. '_HELP)
"-" (dash) commandline prefix (invokes a non-dialog version of a command - e.g. _-LAYER)
"_" (underline) non-localized command prefix (original english command names in a localized version of AutoCAD - e.g. _LINE)
"." (dot) non-redefined command prefix (e.g. for commands undefined using _UNDEFINE, example: ._LINE or _.LINE)
"+" (plus) dialog tab prefix (for selecting a particular dialog tab - e.g. '._+DSETTINGS), or a special command mode (e.g. +PUBLISH)
To list all commands which can be prefixed with "+", type "+" on the commandline and press the TAB key repeatedly (since version 2006). Similarly, to list all transparent commands, type "'" (apostrophe).
Viewports could be another option:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
Patchy
It takes same amount of clicking..😀 as zoom previous.
mgorecki
Thank you, I was missing the "-" in "-view".
mgorecki
Hi Patchy, it depends on how many times one had to zoom or pan I guess.
I was just using 'view which didn't work as you posted earlier.  I needed to use the '-view for it wo work as an inline command.
