Using Palmslam lidar in Autocad
nodink
Message 1 of 8
nodink
I'm wondering if any1 here try this out yet... planning to purchase a lidar scanner for my little project at home.
Replies (7)
Message 2 of 8
pendean
Community Legend
Community Legend
@nodink  Does your scanner state it's software is fully integrated with AutoCAD specifically? Not CAD, but AutoCAD?
Or it does generate PointClouds or DXF or DWG files that are specifically stated to be AutoCAD usable? Not CAD, but spells out AutoCAD?
Message 3 of 8
autoid374ceb4990
Many years ago when the laser scanners were just getting started, we had one of the companies selling the scanners come out and demonstrate the capabilities of the hardware/software.  I would suggest you do the same.
Message 4 of 8
BhaskarMurari
You can use Autodesk ReCap Pro to work with point cloud data from a LiDAR scanner. It allows you to process and link point cloud data directly into software like Revit 2024 for your projects.
https://www.autodesk.com/autodesk-university/class/Intro-Laser-Scanning-ReCap-Pro-Revit-Future-2018
Message 5 of 8
lauri_barnhart
Hi @nodink,
I wanted to check in and see if you saw @pendean's follow up questions and you still needed assistance, or if you found a solution to your question already?
Or did the information provided by @autoid374ceb4990 or @BhaskarMurari help you and answer your question?
If yes, please click on the "Accept Solution" button. This will assist other community users in finding and benefiting from this information.
If not, please do not hesitate to give an update in this thread so all community members receive an update on the progression of your question, and can suggest next steps that may be helpful for you to achieve what you're looking for.
All the best,
Lauri | Community Manager
Message 6 of 8
nodink
I have and no solution to my question about PALMSLAM LIDAR.
Message 7 of 8
autoid374ceb4990
I found this website which allows you to ask a question about the scanner:
https://category.yahboom.net/products/palmslam?variant=50620100903228
The file formats produced by the scanner are listed as:  ROS, pgm, yaml raster map - none of which I am familiar with.  I would think converting these formats to something AutoCAD might recognize could be a major problem.
Message 8 of 8
nodink
I knew about that site already. Just testing the water here, that's all. Thanks.
