Using Fillet w/ Radius set to 0 to make lines meet at right angle
MRf17DA3PT
Observer Observer
MRf17DA3PT
Observer
Observer
On the 2020 version of AutoCAD, I would often use fillet with radius set to 0 to make 2 lines meet at a right angle,. I have been trying to use this function in AutoCAD 2023, and it does not seem to work the same way it did before. Did something change in the version to prevent me from doing this, or is there another simpler way of making 2 lines connect at a right angle?
Patchy
Check your fillet command,
fillet, trim or NO trim
MRf17DA3PT
Observer
Observer
That worked. I didnt think to check that lol. Thanks for your help.
ВeekeeCZ
Also note that you don't have to set the radius to 0, you can just hold the Shift while selecting a second object.
ChobeeCADastrophe
Holding SHIFT is not working for me. Preview for square corner shows, but will not execute the command. Additionally, holding SHIFT for TRIM/ EXTEND is not working either. Any suggestions? I'm certain its a tick box somewhere.
-m@
Kent1Cooper
@ChobeeCADastrophe wrote:
Holding SHIFT is not working for me. Preview for square corner shows, but will not execute the command. Additionally, holding SHIFT for TRIM/ EXTEND is not working either. ....
[Do the objects in question perhaps not lie in the same plane?  Maybe that's not the question to ask, if the preview shows what you expect, but just in case....]
Kent Cooper, AIA
ChobeeCADastrophe
No, but I think I figured it out. I was using Raster Design earlier and the LEFT-CLICK SHIFT toggle was on. I turned it off, and seems to be working as usual now. Thank you.
-m@
