Using DWG to PDF to rotate resulting PDF file?
I use Batch Plotting to create Multi-sheet PDF files. If the drawing I want to plot is in Landscape orientation, is there any way to change the settings so the end result is rotated 90 degrees (i.e., still landscape, just rotated)? It's a "Catch-22": If I use Acrobat Distiller, I can make individual plots rotate like I need them to. But, I can't use the Distiller to create multi-sheet files using Batch Plotting (unless I'm mistaken). Of course, I can use Adobe Acrobat to rotate the individual sheets. But, that's getting old. Not sure it makes a difference, but I always plot from Model Space; so I'm plotting multiple .dwg files.
