Using DWG to PDF to rotate resulting PDF file?
INGOKUENZEL2159
INGOKUENZEL2159
I use Batch Plotting to create Multi-sheet PDF files. If the drawing I want to plot is in Landscape orientation, is there any way to change the settings so the end result is rotated 90 degrees (i.e., still landscape, just rotated)?  It's a "Catch-22": If I use Acrobat Distiller, I can make individual plots rotate like I need them to. But, I can't use the Distiller to create multi-sheet files using Batch Plotting (unless I'm mistaken). Of course, I can use Adobe Acrobat to rotate the individual sheets. But, that's getting old. Not sure it makes a difference, but I always plot from Model Space; so I'm plotting multiple .dwg files.
pendean
Community Legend
Community Legend
Nothing with BATCHPLOT to a built-in PDF to create a multi-sheet single PDF file does that in one single shot, if I understood your need correctly.
Volker_C
Autodesk Support
Autodesk Support
Hi @INGOKUENZEL2159 -
I'm not sure if I'm understanding the question, but have you tried creating a Page Setup with the required rotation and using that as an override in your batch plot?
To Change the Page Setup of One or More Sheets in a Drawing Set for Publishing
To Work with Named Page Setups for Plotting
Please let us know if your questions have been answered by selecting, "Accept as Solution"
Volker C.
CTS Technical Enablement Specialist | AutoCAD
Autodesk Customer Council | Only One AutoCAD | AutoCAD Blog
INGOKUENZEL2159
Yes. I have tried that. It does work to an extent if I choose Acrobat PDF creator under Page Setup. However, each drawing sheet gets generated as an individual file...
hak_vz
@INGOKUENZEL2159  For rotating, splitting and other stuff related to PDF files you may try https://pdfsam.org/
There are other programs you can use. I have started using PDFsam for similar problems as yours.
Miljenko Hatlak
dany_rochefort
I created a Lisp file to rotate my drawings 90 degrees for that same purpose. And a command to rotate everything back into place, save and close each drawing.
