using annotative blocks
MKH-VB
MKH-VB
we've got an issue with blocks, as I am sure others do too. I have uploaded a block of our power pole (PP).  If I insert this block as/is, i can drag the text around using a grip.  I would like to make this block annotative to where whatever my view rotation (dview) that it will appear horizontal.  I can do that, but when I do, the grip for moving the text around is gone.  Is there some way that I can redefine this block to scale/rotate based on the viewport, but also grip the text to move it out of the way? Any help will be greatly appreciated.
mkh
john.vellek
Hi @MKH-VB,
I am able to duplicate this behavior too with your block.My first thought is to do this with a dynamic block with a chained point parameter.
Here is a link to an older post that sounds very similar to this situation.
John Vellek
john.vellek
Hi @MKH-VB,
I am checking back to see if my post helped you with your problem or if you need additional assistance or information. Please add a post with how you decide to proceed and your results so other Community members may benefit.
If the dynamic block suggestion looks like a possibility for you, I suggest that you add a post to the forum for Dynamic Blocks here.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
MKH-VB
i posted in the other forum but have heard nothing. I have not had the opportunity to try your suggetsions. Thanks
mkh
