Using ADCENTER to search for text string
mpa-la
mpa-la
Trying to use ADCENTER to search a directory for a drawing with a particular text string in it (mtext, dtext, mleader or qleader).  To test I put a unique word in one drawing and saved it in a directory with other drawings.  Used ADCENTER to search the directory the dwg is in.  Told it to look for any *.dwg filename, then under advanced I added the unique word into the "containing text" line.  Search results include every file in the directory. : - \  Btw, I'm using adcenter because nothing else I've tried (windows, agent ransack, Everything Search, DWG Search, Total Search) will reliably search drawings for text.  Any ideas?
rkmcswain
I can't comment on the search tools in ADC, but have you tried the external tools here? The top 3 or 4 look like they would work.
mpa-la
I tried "And Where Was That" and it didn't work, but I couldn't even get it to find a file by filename when I only had one file on the list to search.  It was not the most straightforward software I've ever used.  I don't see any others on the list that seem to search for text.
pendean
Community Legend
Community Legend
That function is only designed to look in blocks and attributes, like it says on the pop-up:
Or as a field in DWGPROPS in the file:
If you are looking for anything else, it's not an option.
Dean Saadallah, I've just been upgraded to AutoCAD 2018 from 2015.  In 2015 I successfully used ContentExplorer to search any set of indexed DWG files for any type of text.  ContentExplorer is now missing from 2018.  There is no way to search a group of DWG files for a character string.  It just does not work.  Using Windows Explorer does not work.  This was a critical tool that I've used for years.  Are there any viable alternatives?
