user interface
user interface
user interface
 only the cross-hair area is clear other areas are blur....
what is the solution for it to see all areas to be clear...???
chriscowgill7373
Let's start with the simple stuff and narrow down from there.  have you tried turning off hardware acceleration?
At the command line type 3DCONFIG and provide a screenshot,then turn off Hardware accelerstion.  the screenshot will allow us to see your video card and drivers sso we can make recommendations based on that info.  turning off ha will tell us if it is related and we can then narrow down which feature is the cause.
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2024 on Windows 10
thank you for the reply sir.  just now i found the problem that in performance tuner smooth display was not on and then in manual tune i have on the smooth display. now all areas of interface are clear.....
