>> I want to use Hatches to reflect the condition of a work area:
>> work started, worked complete, work stopped
That sounds like ready to use functions for GIS or FM(facility management).
There does not exist a function out of the box in AutoCAD that let change the colors of hatches in a drawing file. So you need to do a bit development (as long as you don't want to use GIS or FM systems). Which development tool are you aware with?
And are you really sure to start that development, because I guess changing the color of a room is just a first step from such systems. 😉
To identify objects and change then their properties you might
- use the objects handle (handle is something like an ID in AutoCAD, valid only within the dwg-file)
- use a block that contains attributes and hatches, the attribute can then contain an ID to do the search and then change the block's layer to get the other layer's display properties.
- (and I guess others have good ideas too)
- alfred -
Alfred NESWADBA
www.ish-solutions.at ...
blog.ish-solutions.at ...
LinkedIn ...
CDay 2026------------------------------------------------------------------------------------
(not an Autodesk consultant)
