Unusual object highlight when opening drawings - AutoCAD 2025
JBerns
Advisor Advisor
Message 1 of 12
JBerns
Community,
Since upgrading from AutoCAD 2022 to 2025, my coworker experiences unusual object highlighting while opening most drawings. The objects appeared highlighted for 1 - 2 seconds...
and then generally return to normal.
Occasionally, the objects appear pixelated. In those instances, scrolling the mouse wheel causes the screen to refresh and then all appears normal again.
I have been able to reproduce the problem on my PC using his exported/imported AutoCAD settings.
See the attached video.
I discovered that if I change MENUBAR from 1 to 0, the highlighting stops. Enable MENUBAR and the brief highlighting returns.
Three different graphics cards and multiple drivers tested - the highlight behavior occurs with MENUBAR = 1.
Hardware Acceleration off stops the highlighting, but also lose performance.
What in the pull-down menus could be causing this behavior?
When using the Drafting & Annotation workspace (out-of-the-box with AutoCAD), and MENUBAR=1, no highlighting occurs.
This leads me to believe there is something in the workspace(profile) causing the highlight behavior.
BTW - I have another coworker that also uses MENUBAR=1, and his system does not exhibit the highlighting when opening drawings.
This is a puzzler. Hope someone can help.
Jerry
This post has been edited due to: @heather_tracy added the product to the title to help more community members find this topic.
CAD Administrator
Using AutoCAD & Inventor 2025
Autodesk Certified Instructor
Autodesk Inventor 2020 Certified Professional
Autodesk AutoCAD 2017 Certified Professional
Replies (11)
Message 2 of 12
paullimapa
Definitely looks like a graphics card compatibility issue. Try the following
At command prompt enter:
GFXDX12
0
Thats a zero, close & restart AutoCAD
If still no good, at command prompt enter:
GRAPHICSCONFIG
Select another option under 2D Display Settings
Paul Li
IT Specialist
@The Office
Message 3 of 12
JBerns
@paullimapa,
I tried two different workspaces. Brad was migrated from 2022. The Design & Annotation workspace is a default installed with AutoCAD 2025.
Test results for GFXDX12 and GRAPHICSCONFIG:
WorkspaceHard. Acc.GFXDX12MenuBarHighlght-Open
BradON11Yes
BradON10No
Des. & Annot.ON11No
Des. & Annot.ON10No
I discovered that both Hardware Acceleration and GFXDX12 could be On regardless of active workspace.
When using the Design & Annotation workspace, no unusual highlighting occurred with MENUBAR=1.
Our thought was that if the problem was card/driver related, it should occur with all workspaces or MENUBAR settings.
Why would turning on pull-down menus cause this highlighting behavior?
On Monday I can explore other options in GRAPHINCSCONFIG..
Jerry
CAD Administrator
Message 4 of 12
paullimapa
FYI: If problem arises, I would always avoid migration...have a great weekend!!!
Paul Li
IT Specialist
@The Office
Message 5 of 12
JBerns
Ackn. May need to rebuild from scratch.
And a good weekend to you too, Paul.
CAD Administrator
Message 6 of 12
heather_tracy
Hi @JBerns,
I wanted to check in and see if you still needed assistance, or if you found a solution to your question already? Let us know if you need further assistance by providing an update or if you have found a solution, please share it with the community so other members who may have the same question could learn from your experience.
All the best,
Heather | Community Manager
Message 7 of 12
JBerns
@heather_tracy,
No solution found other than to rebuild the workspace/menu/toolbars.
Still seems odd that just enabling the MENUBAR causes the issue.
Jerry
CAD Administrator
Message 8 of 12
BhaskarMurari
@JBerns Can you share your AutoCAD profile or settings so that I can test with my machine.
Message 9 of 12
manieshkumar.suresh
Hi @JBerns,
Good day!
Do you have any LISP or plugin with your setting .
Are you able to reproduce the same issue with default setting of AutoCAD.
Could you set SELECTIONEFFECT = 1 and check the behaviour.
Could you set AutoCAD to use high performance graphics - https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-force-your-...
Maniesh Kumar Suresh
Escalation Lead
If this information was helpful, please use the Accept as Solution function — it helps other users.
Message 10 of 12
BhaskarMurari
Have you tried this ?
Also can you share your AutoCAD profile..
Message 11 of 12
JBerns
@manieshkumar.suresh,
Yes, we have several custom LISP routines that load. Other users load the same LISP routines, but do not see the highlight effect.
When I load the profile on my PC, the highlight can be reproduced. When I turn off MENUBAR, the highlight does not occur. All LISP routines loaded.
Jerry
CAD Administrator
Message 12 of 12
JBerns
@manieshkumar.suresh / @BhaskarMurari ,
With MENUBAR = 1 (On), I tried loading drawings with SELECTIONEFFECT either on or off. The drawings opened with object highlighted regardless of SELECTIONEFFECT setting.
With MENUBAR = 0 (Off), the highlight behavior does not occur.
I suspect their is some legacy info in the pull-down menu from previous AutoCAD versions. A rebuild will be required.
Thanks all for your input and suggestions.
Jerry
CAD Administrator
