AutoCAD Forum
1 REPLY 1
317 Views, 1 Reply
It appears that several folks have tried to help on this issue. Were you able to find a solution? Or a workaround? Did any of the posts in the thread help with your issue? Please post back in the thread if you are still having an issue with AutoCAD or Select Accept as Solution for the post’s that helped. Thanks.
1 REPLY 1
Alfred.NESWADBA
Which thread are you referring to?
As this message is placed as new thread instead of an answer to an existing thread we don't know the question/issue you are writing about.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
AutoCAD Inside the Factory
