Unknown command
Unknown command
Unknown command
Hola, estoy teniendo un problema. Cuándo activo modo de referencia a Objetos, me aparece esto.
Es la tercera versión que instalo y me sigue apareciendo el mismo problema.
He intentado de todo lo que he encontrado, incluso lo que soporte me envió y nada me ha dado solución.
Hello, I am having a problem. When I activate Object snap mode, I get this.
It is the third version that I install and I keep getting the same problem.
I have tried everything I have found, even what support sent me and nothing has given me a solution
vinodkl
Hi @Anonymous
In order for the object snap to work, you need to run the command like "LINE" or "PLINE" and then type in ENDP to activate temporary osnap "ENDPOINT" or press shift key and right-click to activate temporary osnap 🙂
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
imadHabash
Object snaps provide a way to specify precise locations on objects whenever you are prompted for a point within a command. So you have to active a command first then you can use object snaps . >> Click <<
Imad Habash
Muchas gracias, me sirvió de mucho.
