Units will not change to mm HELP please !!!
Message 1 of 9
Please help I have tried everything and this is so frustrating . I have set my project units to mm.
When I draw I want to draw in mm say example a wall is 4 metres long I always type out 4000mm now I cant I can only write 4. I want to draw a 150mm wall and I have to always type 0.150. This isn't ideal why wont my units change to mm. Please help other computers work why doesn't mine
PLEASE HELP IM DESPERATE HERE
See my snap shots below from my computer
Replies (8)
Message 2 of 9
imadHabash
i don't imagine why !!! if you try to offset any lines with 4000mm , is there any issue ? also if you turn off Dynmode ( F12 ) any changes ?
Imad Habash
Message 3 of 9
Alfred.NESWADBA
>> I can only write 4
Why can't you type in 4000?
What happens if you try it?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 4 of 9
Hi there thank you for your reply when I type in 4000 is 4000 metres so its massive . I have no idea why it wont change 😞 😞
Message 5 of 9
it then goes completely off my page and goes to 4000 metres 😞
Message 6 of 9
Alfred.NESWADBA
Please make sure:
If your drawing units are set to Millimeter you need to enter the values in Millimeter.
If your drawing units are set to Meter, you need to enter the values in Meter.
>> goes to 4000 metres
If your drawing units are set to Millimeter, and you create a line with 4000 length, then the line is 4000mm=4m long.
Why do you think that entering 4000 (units = Millimeter) creates a line with 4000m? How did you check that?
Which page are you referring to? Could it be that you don't have zoomed out so you can see your 4000mm object on the screen?
- alfred -
Alfred NESWADBA
Message 7 of 9
Hi Alfred my units are definitely set to mm not metres but it keeps drawing in metres.
Attaching an image of someone else's computer you see how it draws in mm , all my settings are to mm but I can't type 402.38 like my colleague can. I have to type 0.402 to get the same exact line as them
Message 8 of 9
Alfred.NESWADBA
Why do you think that the line with 402 as entered length value is Meter or Millimeter (... I don't see any units on the screenshot as AutoCAD does not show them while drawing).
Create a new drawing, set the units to Millimeter, draw a line with 4000 ...  why do you think that this line is 4000m?
- alfred -
Alfred NESWADBA
Message 9 of 9
imadHabash
Things to remind :
  • in your OP , Millimeters in your attached image indicates for units to scale when inserted to your current opening drawing .
  • to check your drawing units you have to check it from  -DWGUNITS  command ( Notice the   prefix )  , from this command you can check your real drawing units .
Imad Habash
