Command Line – How to Paste String
orders3
Message 1 of 9
orders3
Need assistance with pasting a string in the Command Line.
I am attempting to select a text style “style4” and then present a text message at a specific location on the display
I am using Excel to generate the following command lines for AutoCAD 2017.
       textstyle style4 text 30,30 12 This is a test
  • The text style is selected correctly - “style4”
  • The cursor is positioned correctly - “30,30”
  • The angle of the cursor is displayed correctly - “12” degrees
  • But the text is not displayed. I can then manually enter text, but I want to display the text from the command line string.
What I do not understand is the control characters between the AutoCAD commands.
I am a novice with AutoCAD, so please explain in layman terms.  Perhaps with the appropriate string for above.  Any assistance greatly appreciated.
Replies (8)
Message 2 of 9
Moshe-A
@orders3  hi,
i do not think you can do this with excel?! macros or lisps is the 2 way to go (of course there are others)
macro:
^C^CTEXT S style4 30,30 12  0 "Your text";
lisp:
(command "TEXT" "S" "style4' "30,30," 12 0 "Your text" "")
enjoy
moshe
Message 3 of 9
orders3
Thanks for the prompt reply.  Could you provide the actual test that would be pasted in the AutoCAD command line?
Message 4 of 9
orders3
Typo - "Text"
Message 5 of 9
Moshe-A
copy & paste the lisp line into the command line
Message 6 of 9
orders3
Certainly appreciate your patience.  Here is the results:
Pasted following:
Results:
   Command: "TEXT" Unknown command ""TEXT"". Press F1 for help.
   Command: "S" Unknown command ""S"". Press F1 for help.
   Command: "style4' "30,30," 12 0 "Your Unknown command ""STYLE4' "30,30," 12 0 "YOUR". Press F1 for help.
   Command: text" Unknown command "TEXT"". Press F1 for help.
Pasted following:
Results:
   Command: (command "TEXT" "S" "style4' "30,30," 12 0 "Your text" "")
And in the command line:
   ("_>
Apparently, with my original string that I pasted, everything works, except AutoCAD is waiting for me to enter text via the keyboard instead on accepting the string.  What do I need to tell AutoCAD to accept the text?
Really appreciate your assistance....
Message 7 of 9
leeminardi
That should be a quote " not an apostrophe ' after style4 as follows:
 (command "TEXT" "S" "style4" "30,30," 12 0 "Your text" "")
lee.minardi
Message 8 of 9
orders3
Thanks for the correction lee.  But I still have a problem.  Don't know what I am doing wrong.
Pasted to Command Line....
AutoCAD Response:
Command: (command "TEXT" "S" "style4" "30,30," 12 0 "Your text" "")
TEXT
Current text style: "style4" Text height: 4.0000 Annotative: No Justify: Left
Specify start point of text or [Justify/Style]: S
Enter style name or [?] : style4
Specify start point of text or [Justify/Style]: 30,30,
Point or option keyword required.
; error: Function cancelled
Message 9 of 9
orders3
Thanks Lee  for all the assistance.  I finally got this to work.
(command "TEXT" "S" "style4" "30,30" 12 "Your text").
It appears to be simple and I am embarrassed that I could not figure it out myself.
Have a good day....
