Unique Deviation Report
CADTACULAR
CADTACULAR
I'm trying to figure out if there is a way to create a deviation report based on a grid.  So Say I import points from a plane. Set a zero. Then overlay a gird to the points.  Optimally I would be able to automaticly have the closest point to each intersection picked and noted with a deviation from my zero. Or I would have to go through manually and pick the points closest to the grid.
What is the best way to do this?
and
What version of CAD do I need?
leothebuilder
With heavy customization you can probably achieve this.
Post this question in the customization forum.
Any version of autocad.
CADTACULAR
Thanks for the responce. I will give that a shot.
