Unicode in atrribute
Hello, I have searched the AutoCAD help files to find how to put the cubed symbol in an attribute and have found that with a romans font it should work with \U+00B3 or alt+0179.  My company standard font is romans so I cannot change it to a different one.
http://help.autodesk.com/view/ACD/2017/ENU/?guid=GUID-518E1A9D-398C-4A8A-AC32-2D85590CDBE1
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2017/ENU/AutoC...
Is this correct because it does not seem to work anymore?  I get a "?" mark in the dialog box and on the drawing when I use \U+00B3 and I get the cubed symbol in the dialog box and a "?" on the drawing when I use alt+0179.
Dan
imadHabash
>> Is this correct because it does not seem to work anymore? <<
it's still work ... would you please attache here a CAD drawing (just a text) sample and see what happened next ?
Imad Habash
I believe the root of the problem is in Microsoft Windows as it is not posted in the character maps anymore.  Have a look for yourself.
I am currently using Microsoft Windows 7 with AutoCAD 2015 x64.
Dan
dmfrazier
I get results similar to what you describe with Acad 2014 on Win7 64 when the text style of the attribute is based on an AutoCAD SHX font.
I have to change the properties of the attribute so that it has a text style defined with a Windows (TT) font to get the cubed symbol to appear in the DWG.
