How to convert dwg to igs
Message 1 of 11
Hi,  somebody knows how to convert dwg to igs?
Replies (10)
Message 2 of 11
skintsubby
Type "EXPORT"
Then change the format to "*.IGS"
....and.... I even managed to get a reply in before Alfred.. Smiley Happy
Message 3 of 11
Hi @Anonymous,
Welcome to the Forum ...
Hope this link helps ... > https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/AutoC...
Message 4 of 11
There is no igs format in my AutoCAD 2017, so I can't export as igs file.
Message 5 of 11
Alfred.NESWADBA
can you please show us 2 screenshot?
  • one when you started command _EXPORT and open the filetypes-list (like shown below
  • a second screenshot from the dialog after starting command _ABOUT
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 6 of 11
here is
Message 7 of 11
skintsubby
Are you using a Mac?
If so you should post this on the Mac forum <<HERE>>
Message 8 of 11
Alfred.NESWADBA
thank you for your screenshots.
Sorry to say that AutoCAD on Mac does not have the export and import function for IGS.
If it's a one time case upload the DWG-file here and I'll convert it to IGS, if you need that more often you might think about a Windows version of AutoCAD on bootcamp or VmWare or anything similar.
- alfred -
Alfred NESWADBA
Message 9 of 11
Thanks. Here is the file.
Edited by Request
Discussion_Admin
Message 10 of 11
Qualcuno potrebbe convertirmi un piccolo file DWG in IGS? Sono un'esperta ... Grazie
Message 11 of 11
S_Sohel
Community Visitor
Community Visitor
thanks, it was helpful.
