understanding edit lin file to create linetype incl. text to show proper
edenbU7RGS
edenbU7RGS
I reads many guides which describe how to edit the lin file to create linetype incl. text.
I tried to understand it by making trial and error but still something is not completely understand.
I just want the line will show the text itself and a little space before and after, like in the "WR Ø4" in the screenshot below.
I couldn't make it for the two other lines the circle in red.
*DCW-Pump 1.5inch,DCW-Pump 1½" ---- DCW-Pump 1½" ---- DCW-Pump 1½" ---- DCW-Pump 1½" ----
A,.9,-1,["DCW-Pump %%c1%%189%%34",WinHeb_D2W,S=.1,U=0.0,X=-0.1,Y=-.05],-1
so what's the ratio should be between the valves? or maybe not ratio just other method? im talking about the valves: ".9" "-1" and "-1" in the end of string.
Topic: Modifying line types in Autocad (foresoft.com)
Creating Custom AutoCAD Linetypes (thecadmasters.com)
pendean
Community Legend
Community Legend
Share that DWG file in your screenshot please.
edenbU7RGS
there it his
Kent1Cooper
You would need to either increase the -1 at the end [the "pen-up" distance], or use a font in the WinHeb_D2W Text Style definition that has narrower characters or closer character spacing.  Unfortunately, you can't just reduce the width factor in the Style definition -- in linetype text inclusions, the Style's width factor seems to be ignored -- so if you want the text to fit in the gap you have at the height you have, you'll need a font with a "native" width that is narrower.  That's why it's probably easier to increase the pen-up distance.
Kent Cooper, AIA
