AutoCAD Forum
Unable to view object data
1 REPLY 1
387 Views, 1 Reply
Greetings everyone,
This is an AutoCAD 2011 related question about being unable to see under properties objects that I have attached to polylines in AutoCAD Map3D.
I have created an map3d .dwg that the polylines and points have attributes attached (objects). However, when I access the same file in plain AutoCAD nothing appears under properties.
Is is a format, import settings tweak or simply it can not be done?
Thank you in advance.
Greetings everyone,
1 REPLY 1
Murph_Map
Murph_Map
Object Data is a Map3D function and only available with Map3D or Civil3D. That includes viewing it in the property palatte. Might look at Dotsoft Mapworks.
Murph
Supporting the troops daily.
Murph
AutoCAD Inside the Factory
