Hi, so I am currently trying to follow along with a video on how to make an object and came across a problem. In the video that I have linked below, at around 8:20-8:24 he starts to use the trim tool to get rid of the bottom half of the circle in order to presspull. However as I was attempting to do the same I was unable to selectthat line in order to start trimming. I have tried setting my settings back to default but I am still having this problem. The line was made through the tool copy edge and when I try and click on it in order to trim, I simply get an error message saying 1 is not a valid edge/selection method. Or that I am unable to trim this object. The video is:
https://www.youtube.com/watchv=U3kGINzBOk&list=PLrOFa8sDv6jcfsE__xMC2Igl3Y3DXhs8g&index=2.
thx for posting the video, but can you show what your problem is?
Share your .dwg and a screencast, or explain your trim steps and at what point you can't follow the video - and what happens instead.
Sebastian
Hi, I have added the details to the original post. It seems that my message wasnt properly written and got attached to the hyperlink, but it should be showing now properly. Thanks!
all lines and circle created, you have to select the line enter and the circle, not a 3dobject.
And if your trim mode is set to quick mode, you don't need to click the line.
Start trim, checkout the current mode [F2]
Sebastian
