UNABLE TO SLICE
UNABLE TO SLICE
Message 1 of 14
UNABLE TO SLICE
Can any one help me to slice the solid i made according to the attached image <CAPTURE.PNG>..
Replies (13)
Message 2 of 14
pendean
Community Legend
Community Legend
Thanks for the screenshot: if I understand your desire correctly SLICE command does not work like that red line, it will require two actions or two copies of your model sliced twice and brought together.
Message 3 of 14
i am a beginner and unable to understand you thoroughly and if you can do this for me and elaborate the process vastly .
Message 4 of 14
Patchy
Draw a polyline, copy it and loft them, then use it as a surface to slice.
Message 5 of 14
done. but it is not working
Message 6 of 14
Patchy
Are you sure all parts are 3d solid? save your drawing to 2007 version and post it for me.
Message 7 of 14
parkr4st
2007 save attached
The parts do not abut cleanly.  there are gaps between the clevis rings and the adjoining half circle faces of he filling part.
Message 8 of 14
parkr4st
file 2007
Message 9 of 14
Patchy
I need a new PC, this is what I got ☺
Message 10 of 14
SEANT61
Part of the problem may be that the drawing units are in millimeters but the part is situated about 84 Kilometers away from the origin.
May your cursor always snap to the location intended.
Message 11 of 14
j.palmeL29YX
I'd suggest first completely to build your model new.
I tried this:
- move all 3Dsolids near to 0,0,0
- Union the 23 3D-Solids
=> I get an Error Code Number is 84030
Before searching what causes the error I think it's much easier, to create the model completely new.
If this is done post it again and we will show you how to slice it(if necessary).
Jürgen Palme
Message 12 of 14
j.palmeL29YX
In the meantime I played a bit with your model. I could union 22 of the given 3D-Solids successfully, the cylinder bottom right ( I moved it a little away) causes an error.
If the model would be correct and precise, then a lot of edges should not be visible. (some of them I marked in the attached pic).
Jürgen Palme
Message 13 of 14
Johanna_Esteban
Hi @nasamayank1
I attached file dwg with the editions shown on the screencast, no errors were presented, the solids were edited without major difficulties.
>>> 3D solid edited with a CTRL key <<<
I hope I have resolved your concerns with it.
Johanna Esteban
Autodesk Expert Elite | Autodesk Certified Professional | AutoCAD Customer Council (Beta Tester for Windows & Mac)
¿Te ha parecido útil este post? ¡Dame Kudos! 😉
Si ha sido resuelta tu inquietud, selecciona 'Marcar como solución' para que otros usuarios la encuentren fácilmente.
Message 14 of 14
parkr4st
I agree.  same redrawing, corrections, required.  This is one example.
