Hello everyone,
im new here and this is my first post. I am using Autocad 2014 and im trying to save a dwg to dxf but it keeps on saving and saving and saving, it never finishes saving it. i hope you guys understand what im talking about. I need to specifically save it to Autocad R12 dxf format. thank you.
Solved by john.vellek. Go to Solution.
Have you tried to AUDIT and PURGE your document before saving to DXF?
CADnoob
Hi Planning_Tech
Try saving the drawing down to the oldest version you can first and then try to create the DXF. Running Audit and -Purge will also help you to clean up the drawing. You could even wblock the entire contents of the drawing to a new file to see if that helps with the issue.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
I've tried the PURGE and AUDIT command and also saving it to a lower version and then saving it to dxf and NOTHING! Still doing the same thing. It just keeps.....saving........saving.....0%. The reason i cannot use a different dxf format is because the program where im importing it, does not recognize any format but R12 dxf.
Hi @Anonymous,
Can you attach the file so I can take a look at it for you?
Hi @Anonymous,
I ran EXPORTTOAUTOCAD to clean the drawing file up. After that I was able to create the DXF file
Hi @Anonymous,
I am glad that it was such an easy fix. Your drawing had a bunch of DGN definitions in it which is likely what caused your problem. Exporttoautocad is a great command for fixing such issues.
Hello to anyone!
After reading the comments about how this particular problem was solved, I can say that in my case the same did not happen. I have version 23 and when I go to save to dxf the file is finally in format dwg again. And the symbol of dxf doesn't show. Still looks like dwg.
Any ideas?
