We have been using AutoCad on iMac without a problem, up until today, when we installed a new computer. CAD worked fine, the only problem is when we try to plot the drawing to pdf. All the setting are the same, but no pdf is created. Nothing happens- not even an error message. I cannot find an answer to this issue in the forums- and can't figure out the issue. Any ideas would be very much appreciated- have to fix this ASAP! Thank you.
Perhaps you can provide more detail of the new computer.
Is it another Mac?
Is it a Windows computer?
Which AutoCAD version are you using?
List the Plot steps you're taking to create the PDF from AutoCAD.
Are you able to print from AutoCAD to a printer if you don't create a PDF.
Area Object Link |
Attribute Modifier |
Dwg Setup |
Feet-Inch Calculator
Layer Apps |
List on Steroids |
VP Zoom Scales |
Exchange App Store
I don't know if this is the issue, but as an example, if I print to my Bluebeam PDF printer, and the Bluebeam PDF print service is not running, I get the same result as you are saying... nothing.
Can you print from other applications to this PDF driver, such as Word, Excel?
Your screenshot didn't display on your post.
Couple of things to try in addition to @rkmcswain's suggestion of seeing if your pdf driver work with other applications:
