unable to paste
unable to paste
Soumya.Naik
Message 1 of 9
unable to paste
Soumya.Naik
I'm trying to copy some items from the drawing and pasting it into another drawing but when i paste (ctrl+v) the item shows up as soon as i click any point to paste it the items get disappeared. Please help ASAP if anyone has any idea.
Replies (8)
Message 2 of 9
imadHabash
I suggest to check your layers status .. LAYON  and/or LAYTHW commands may fix your issue.
Imad Habash
Message 3 of 9
Ed__Jobe
The second image shows that the object you are trying to copy is an xref. So the command fails. Use the XREF command to reference the file instead of copying it. Alternatively, you can try right clicking and choose Clipboard>Paste As Block instead of just Paste.
Ed
How to post your code.
Message 4 of 9
Kent1Cooper
@Ed__Jobe wrote:
... the object you are trying to copy is an xref. So the command fails. ....
I wondered about that, too, since I had never thought to copy/paste an Xref, so I experimented.  I Xref'd a small drawing into another, and Ctrl+C copied it from there, then Ctrl-V pasted it into a different other drawing, and it did come in successfully, and as an Xref.  So I think that in itself is probably not the issue.  I am inclined to share @imadHabash's suspicion about the Layer(s) of what is pasted being off or frozen.
Kent Cooper, AIA
Message 5 of 9
Ed__Jobe
@Kent1Cooper I just did some more tests with layers locked/off/frozen. I was unable to duplicate the OP's results. The current layer can't be frozen. The xref pasted to a locked and off layer and all the xref layers were on. I did this pasting into a clean dwg.  @Soumya.Naik We would have to have a copy of your dwg and xref to test further.
Ed
Message 6 of 9
Soumya.Naik
no issues with layers.
Message 7 of 9
Soumya.Naik
It is showing that its xref but they are some DI blocks and Polylines from another drawing.
Message 8 of 9
Soumya.Naik
@Kent1Cooper they are DI blocks and polylines from another drawing but not sure why its showing that as a xref. In fact I'm not able to paste anything into this drawing from any other drawings not even text, lines, block nothing.
Message 9 of 9
Soumya.Naik
@Ed__Jobe @Kent1Cooper @imadHabash may be drawing has some issue I detached all xrefs and tried pasting blocks and its working.
