Unable to open the visual styles manager
Message 1 of 18
Hello.
I am trying to open the visual styles manager panel, but it will not.
Once I click there, the command applies and I can see it below in the command bar, but nothing happens though.
I have tried directly typing the command, looking for a solution in the forums, but nothing.
I don't remember changing any configuration lately and I have tried in other devices, and it seems to be working normally. Also, it doesn't look like the visual styles panel could be hidden somewhere, or at least I can't see it.
Regards.
Replies (17)
Message 2 of 18
imadHabash
would you try from below command line and type VISUALSTYLES , any changes ?  if not fixed please change your workspace and see if any good results ?  or try as below image
Imad Habash
Message 3 of 18
ennujozlagam
you can try to reset setting to defaul of your autocad and see if helps. thanks
Message 4 of 18
- I have tried to type the command --> nothing happens
- I have changed to a different workspace --> I can't make the palette to appear
- I tried in your way --> visual styles palette appears like enabled, but it doesn't matter if I enable it or not, it doesn't make anything. The funny thing is that the other palettes, like Materials editor, for instance, work perfectly fine.
- I tried also in this other way:2019-07-10 10_10_31-Autodesk AutoCAD 2018 - [Drawing1.dwg].png
It seems like my Visual styles palette is already enabled, but I can't see it.
Thank you very much
Message 5 of 18
ennujozlagam
just a wild guess. try to switch off hardware acceleration and see if helps. thanks
Message 6 of 18
imadHabash
would you try this :
Use the keyboard to move the window into view. Try this first on a visible window to see what happens:
  1. Execute the command to activate the dialog window.
  2. Press Alt+Spacebar on the keyboard.
  3. Press the M key and tap an arrow key.
  4. Move the mouse to bring the window into view.
  5. Click the left mouse button to cancel the operation.
Imad Habash
Message 7 of 18
For some mysteries of life, that option of reset settings is not available for the english version of my autocad.
Curious thing is that in my german version the visual styles panel works fine. I restored settings in the german version anyway to see if by luck it restores everywhere, but I was too optimistic.
However now anytime I need to change my visual styles I have to open the autocad in another language and do it from there. I guess is a halfway solution.
So thank you very much!
Message 8 of 18
I have disabled it, but still the palette doesn't appear.
What does this option make? If I switch off the hardware acceleration the software will go faster when I make my 3D designs?
Message 9 of 18
I am trying to do what you said in your post, but It might happen I don't understand your steps
Message 10 of 18
imadHabash
If you have a video card that supports OpenGL, you can enhance your graphics performance and productivity when working with 3D models by turning on hardware acceleration. This will improve your overall performance, not just with 3D work. Some video cards and drivers that support OpenGL are not compatible with AutoCAD when hardware acceleration is turned on. This incompatibility may result in some unexpected problems. To test for optimized working conditions in your environment, you can switch hardware acceleration on and off.
Imad Habash
Message 11 of 18
imadHabash
some times dialogues exist some where there but shifted off the screen !!! by those steps we can get them back on the screen .
Imad Habash
Message 12 of 18
I think this is exactly what happens to me. This is what I am doing following your steps:
1. I type in the command bar the command "visual styles"
2. I press Alt+space bar --> then this panel pops up
3. Then I tap M in my keyboard (I suppose you want to select the Move option, however Move appears disabled). When I tap M the panel closes and I come back to the model space of autocad
4. Now If click and arrow there is no effect
Am I doing it correctly?
Message 13 of 18
imadHabash
Yes that's right .... BTW have you try from your CAD screen ( see below image )
Imad Habash
Message 14 of 18
Yes, I have tried now but It doesn't work.
Can you tell me what command appears in the command bar when you open the visual manager, and then you select the option "create new visual style"? Maybe I can try tiping the order directly, but now I don't know because I can't access it.
Message 15 of 18
imadHabash
try -VISUALSTYLES (Command)  >> Click <<
Imad Habash
Message 16 of 18
This command send me to options, but not the one to configure a new visual style
Message 17 of 18
grgmrtnz
It's 2023, 4 years since @Anonymous experienced this weird AC behaviour and still nobody has posted a solution/explanation... and now I'm experiencing it
(ACAD 2022 - 3D Modelling UI)
Message 18 of 18
DumR0
HI
Try to modify your screen resolution(display setings) 1280x720, step 2 came back at the recomanded resolutin
might help
