>> Invalid or incomplete DXF input
Is that DWG-file created from AutoCAD or was it created or modified from a vertical product like AutoCAD Architecture/Civil3D/Mechanical ... or are components inserted from somewhere else?
If you start your AutoCAD 2018, start command _ABOUT ... which version information do you get? (a screenshot would be great so we know what version exactly you have).
When you open the DXF-file in AutoCAD 2014, is that plain/Vanilla AutoCAD? (command _ABOUT and a screenshot would help here too).
When you start command _AUDIT after you opened the DXF in AutoCAD 2014, do you get errors shown?
At least, if you could ZIP the DXF-file and upload the ZIP-file we can take a look to your file on our systems.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ...
blog.ish-solutions.at ...
LinkedIn ...
CDay 2026------------------------------------------------------------------------------------
(not an Autodesk consultant)
