Hi @Anonymous,
Before resetting let's try a couple of things:
1- I don't know if you know that shift+ right click shows a snap menu when ever you're asked for points..
2- Have you tried @Anonymous suggestion - post5?
3- You may also want to try this:
-toolbars > all > show
and close what you don't want and leave only object snap..
4- If none of that worked:
A- Backup your Workspace:
- Click on icon like a gear in the bottom right corner of the screen, and "Save current as" a new work space, and name it "My_WS" for example..
- Click on the same icon and make the new workspace current..
- Click on the same icon and choose settings..
- Make the new created work space your default (my workspace= My_WS), and check "Automatically save workspace changes"
B- Add toolbars to your new work space:
- In the command line, enter CUI
- In the left top tree you'll see the work spaces including the new one (My_WS), select it..
- The contents of this work space will appear in the top right area, and it's properties in the bottom right..
- In the contents area you'll see a node called tool bars, with nothing inside (or without the object snap toolbar)
- There is another node called toolbars under the workspaces, expand it and drag the Object Snap tool bar from there to tho node in top right
(Dont click on the tool bar and stop, drag it immediately - to not show it's own properties instead of the Workspace in the top right)
- Ok - the toolbar should appear..
If none of the above worked, go to the start menu > > progams > Autocad (or autodesk) folder> reset setting to defaults.. --- then try again all the previous steps (-toobars ....)
Regards..
